ken jennifer preston
About ken jennifer preston
  • Birthday 09/08/1943
    Newcastle N S W
    Travelling Fishing
877 profile views
ken jennifer preston's Achievements
  1. I have a 2012 XC3, can anyone shed some light on the fact that when the van is disconnected to the vehicle, I have no power to the Anderson plug on the draw bar? My old ATV II used to always have 12 volts of power to the Anderson plug which was handy to run a water pump or fridge etc. I have checked all fuses and none are blown, I cannot find a diode in the front boot anywhere that would prevent 12 volts from flowing in either direction? Seems odds that the system is set up to only allow 12 volts to flow from the tow vehicle to the van and not in the other direction. Does anyone have an experience with this, I would appreciate your thoughts!! Thanks
  2. Can anyone provide some advice on washing the lounge covers? As you know they are a tight fit and I am worried about them shrinking once washed? Thanks
  3. Hi there, I have a 2006 ATV2, and have a few LED lights out on the tail lights, made by www.ledautolamp.com. I cannot work out how on earth they are removed and was hopeful that perhaps someone else has undertaken this task and can assist. Kedron factory closed until the 16.1.2014, and a thorough search of the internet failed to locate any information. My lights has three sections all about 3' square. One for the indicator and one each for the brakes and tail lights. However they are no separate, looks like a complete unit. There is no clips or screws that I can see, and access from inside is not an option as the shower is behind one and sink the other. Many Thanks.
  4. Hello Collin We had a similar problem. When you remove the pin, the mechanism that the pin operates doesn't function because of the amount of road grime and grit that has entered the area where the pin has been removed. Try spraying into the area where the pin come out with a good quality CRC and operating the pin several times to help lubricate the internal mechanism. Also check the pin, it has a locking head and the plastic pins have a tendency to break off and stay in - thereby stopping the mechanism from working. Good luck Ken and Jen
  5. Hi fellow members, I have a short post, my Son and Daughter in-law are trying to track down a Kedron with bunks in either a full van or pop top. If you hear of a van that may fit the bill please send an e-mail to Ben at bpreston73@optusnet.com.au Many Thanks
