Ian and Jill Brown
Ian and Jill Brown last won the day on August 28 2015
Ian and Jill Brown had the most liked content!
    Perth WA
1,357 profile views
Ian and Jill Brown's Achievements
  1. Hi Chris, we installed a 400amp lithium battery 12 months ago, have 610 watts of solar and it works a treat (and saved approx. 90kgs in weight). Cheers, Ian
  2. Not all vans are over 3500kgs, our 18' internal 2007 TE weighs in at just under that weight fully loaded (weigh bridge docket) and since changing over to lithium is a further 100kg's lighter. The reason we have not upgraded to a 20' internal TE (though we paid the deposit) is that we could not possibly tow the new van with the cruiser, because of the van weight. We are staying with our current van and very happy with the tug. Cheers, Ian
  3. Hi, We tow our 2007, 19'6 TE (tare 2785kg's) with a 2009 200 series LC with suspension upgrade etc. Our caravan fully loaded comes in just short of 3500 kg's. You should be fine. Cheers, Ian
  4. Thanks Peter & Steve, I should have my battery installation completed on Monday and will 'program' the PL60 then. I will talk to Plasmatronics, as I understood I would be using a modified program #4. Once completed and tested over Xmas/New Year, I will report back on our stay in a c'van park from Xmas to New Year. I intend to not connect to power during this time. A short test to start with. Cheers, Ian
  5. Hi Everyone, I am currently installing 1 x 400 a/hr EV Works lithium battery to replace my 4 x 120 a/hr agms. I have a PL60 controller and was wondering if anyone has done this upgrade and could confirm the program 4 settings? Any help would be most apprecaited. Cheers, Ian
  6. Hi All, We have a Four Seasons hatch mounted on the front sloping section of our caravan roof (I understand Kedron don't mount them there any more) of our 2007 TE. Just to the rear of the hatch there is a radio speaker. On 2 recent occassions, we have had rain water enter thru the speaker. One was whilst we were driving and the other last night in very heavy rain at Port Broughton SA. There is nothing obvious on the roof, but I seem to recall some issues with sealing the hatch and wonder if the water counter enter there and travel 'uphill' to come through the speaker? Any suggestions/comments would be appreciated. Cheers, Ian
  7. Hi All, Has anyone had an issue removing their m/wave unit. I attempted to take ours out in our TE, but the overall height of the unit including feet, is greater than the cabinet opening. Any sugestions would be appreciated. Cheers, Ian
  8. Hi Tony, Thanks for your reply. Yes I followed the number plate post, but on this trip to Cairns, we will 'wing it', as we are looking at ordering a new TE on the way home. Cheers, Ian
  9. Hi, I am thinking about mounting a bike rack on the rear of our TE and between the spare tyres, so the bikes will be located behind the tyres. The number plate would still be clearly visible. Will this break any laws in the e/s? Cheers, Ian
  10. Hi Russ, From memory, you have 4 x 90a/hr Winston batteries in your van. I am currently looking at them and was wondering your thoughts on 2 x 200 a/hr battery cells (8 cells in total) compared to the 4 batteries. I'm not sure if it applies to lithium but I was once told that bigger was better in agm batteries. I would appreciate your thoughts. Cheers, Ian
  11. Hi All, Is anyone using a low wattage kettle with their inverter? In deciding whether or not to go to lithium batteries, the system will have an 1800 watt inverter and as we currently only have a 300 watt inverter (for light duty charging compuyers, phones etc.), we are trying to decide how we would use the available 240 v power. A coffee pod machine will be a must, but not sure about the kettle. Any comments would be appreciated. Cheers, Ian
  12. Thanks John, It looks like this is the way to go. Ian
  13. Thanks everyone for your posts. Confirms my thoughts that this is the way to go. By the way, our 18' TE (internal) weighs in at 3475 kg's fully loaded. Cheers, Ian
  14. Hi Everyone. We have a 2007 18' internal TE that I am thinking about replacing the Hyland hitch with a McHitch. As our van has a healthy tow ball weight - slightly above the 350kg's I was wondering if those that have the McHitch are still using their weight distribution bars and which is the better hitch (for general towing) the 4.5 tonne or 6 tonne? We are towing with a LC200. Any comments would be appreciated. Cheers, Ian
  15. Hi Mal, We found that by using ice block trays with lids, we reduced icing up the freezer by a huge amount. It appears the fridge creates ice by drawing moisture from water/food etc. We had our fridge serviced by the Frdge Whisperer at Kedron last year and it is running as good as the day we bought the van in '07. Cheers, Ian
