Wayne and Cheryl Byrne Posted February 11, 2008 Report Share Posted February 11, 2008 We purchased our Kedron Topender No. 650 second hand and did not come with a generator, we are looking at purchasing one and have read on this site people having trouble with the generator handling the air con. Our air con is a Coleman MACH, we don't have any books regarding the wattage required, does anyone else have this air con and is the honda 2000watt capable of starting this air con?ThanksWayne & Cheryl Quote Link to comment Share on other sites More sharing options...
Rosco Posted February 11, 2008 Report Share Posted February 11, 2008 The Honda 2KVa should do the job however for a few Kgs more have a look at the Yahama EF2400iS. http://www.yamaha-motor.com.au/power/index.htm?power.aspYahama EF2400iS Same noise, 2.4KVa, downside 11Kgs more.To run the A/C very successfully:Honda 30IsORYahama EF3000iSE, Both a lot heavier however the smaller generators labour when trying to run the A/C.The wont fit in the standard generator box though.Rosco :thumbsup: Quote Link to comment Share on other sites More sharing options...
Kimbo Posted February 11, 2008 Report Share Posted February 11, 2008 Totally agree with RoscoI have the Coleman Mach on our Topender and to date havn't suffered any of the problems that others report here to having.We were in Borroloola area mid April last yr and it was very hot there and we ran the aircon on the Generator with no problems Im sure Chris will come on here and report her findings re the Honda and I believe they are going for the Yamaha in the new van Regards Quote Link to comment Share on other sites More sharing options...
Wayne and Cheryl Byrne Posted February 11, 2008 Author Report Share Posted February 11, 2008 Thanks RoscoWe did the measurements and realise that the Yamaha 2400 won't fit in the generator box with the slide that is in there, would have to take it out. We were thinking along the line of the Yamaha but the size was a bit of a problem.Wayne Quote Link to comment Share on other sites More sharing options...
Rosco Posted February 12, 2008 Report Share Posted February 12, 2008 Just a warning. I have it on good authority that the Kipor 2600 generator will NOT run the A/C's.:shutup: Rosco :thumbsup: Quote Link to comment Share on other sites More sharing options...
Chris Posted February 12, 2008 Report Share Posted February 12, 2008 As Kimbo says we had real problems with the Honda running the aircon at temperatures of about 45 or 47 degrees (admittedly it WAS hot outside!). We referred to the manual and it says the ambient operating temperature is below 40 degrees. After having the unit thoroughly checked twice by Honda agents, and no fault found with it, we relectantly decided it must be the factor of the heat on that day. Had similar problems in hot weather at later times too.Julie and Neil have reported the same issue, and they tell me they removed the slide from their Top Ender so the Yamaha 245 would fit in there, and have no problems since in ANY weather.Chris Quote Link to comment Share on other sites More sharing options...
Wayne and Cheryl Byrne Posted February 13, 2008 Author Report Share Posted February 13, 2008 Thanks for the input, we will probably be going with the yamaha as the specs we found for the Coleman Mach says 2117 watts at 35degrees which is outside the honda 2 capabilities.Wayne & Cheryl Quote Link to comment Share on other sites More sharing options...
