Rod and Jen Posted August 6, 2013 Report Share Posted August 6, 2013 Have water to shower but not the sink can't see why any one had this problem. Rod. Quote Link to comment Share on other sites More sharing options...
Merv and Di Posted August 6, 2013 Report Share Posted August 6, 2013 Could either be an air lock in the system or a blockage in the valve at the base of the mixer tap if you have one. Try having the pump on and a combination of hot/cold to see if it clears..otherwise you might just have to pull it apart.CheersMerv Quote Link to comment Share on other sites More sharing options...
Blueheeler Posted August 6, 2013 Report Share Posted August 6, 2013 Hi Rod & Jen, How long has it been since you change your under sink filter? They can block up without warning or it could be an air lock as Merv stated.Cheers,Kingy Quote Link to comment Share on other sites More sharing options...
rovic3 Posted August 18, 2013 Report Share Posted August 18, 2013 Hi Rod & Jen,We have had the same problem. It was caused by the filter on the tap (where the water comes out) being blocked with a white material from the decomposition of the hot water system anode. Our fix is to unscrew this filter, clean it, flush the tap with filter removed.....then replace filter and all is good for a while.Hope this works for you.Ron & Viv Quote Link to comment Share on other sites More sharing options...
