jherron Posted September 23, 2013 Report Share Posted September 23, 2013 Hi all I have a cabled rearview camera to fit to the rear of an Kedron ATV poptop (early model)I'am wondering if anyone out there has fitted same and how?There are many options but I want it to look good without cable dangling every where.I'am reluctant to start drilling holes in the cladding not knowing what is behind and also if I can route it along through the wall frame.Any comments, suggestions or perhaps photos will be welcome. I await your replies Thanks John Quote Link to comment Share on other sites More sharing options...
Merv and Di Posted September 23, 2013 Report Share Posted September 23, 2013 Hi JohnThe easiest way to run your cables will be either through or alongside the chassis rail or one of the floor rails and at the rear of the van a small hole and run it up beside one of the rear wall studs. Us a sturdy fine piece of fencing wire to pull your cable up the wall.CheersMerv Quote Link to comment Share on other sites More sharing options...
jherron Posted September 24, 2013 Author Report Share Posted September 24, 2013 Hi all I have a cabled rearview camera to fit to the rear of an Kedron ATV poptop (early model)I'am wondering if anyone out there has fitted same and how?There are many options but I want it to look good without cable dangling every where.I'am reluctant to start drilling holes in the cladding not knowing what is behind and also if I can route it along through the wall frame.Any comments, suggestions or perhaps photos will be welcome. I await your replies Thanks JohnHi Merv,Thanks for your advise re camera, obviously you have some knowledge as to what is behind the cladding.I wasn't sure if there would be a passage down past the frame without striking a horozontal bar. I was thinking of fitting along the chassis rail but didn't want cable down the outside at the rear of the van.Thanks again Regards John Quote Link to comment Share on other sites More sharing options...
Mrs Lynn Astill Posted September 24, 2013 Report Share Posted September 24, 2013 Hi John,Basically what Merv said, but being a chicken, I would come up inside the cupboards if possible.RegardsChris Quote Link to comment Share on other sites More sharing options...
jherron Posted September 24, 2013 Author Report Share Posted September 24, 2013 Hi Chris,Yes I'am a chicken also that is why I thought I would ask first.I have had another look and will drill a hole at the bottom as Merv mentioned and if the wire doesn't feed up will try inside the cupboards.It's only a matter of a bit of silicone to reseal the hole.Thanks John Quote Link to comment Share on other sites More sharing options...
