mickanann Posted March 2, 2017 Report Share Posted March 2, 2017 solar does not appear to be charging batteries. where should i start to look ? thanks 1 Quote Link to comment Share on other sites More sharing options...
Merv and Di Posted March 3, 2017 Report Share Posted March 3, 2017 HI Mickanann welcome to the forum. A little bit more information is needed to try to solve your problem. How much is in your batteries, how much going in with full sun on panels and if drained can you connect to power either generator or plug to recharge. How old are the batteries. Try reset button your solar controller. Then we might be able to assist. In the meantime checkout your bible and read the instructions re your solar charging. Cheers Merv 3 Quote Link to comment Share on other sites More sharing options...
mickanann Posted April 2, 2017 Author Report Share Posted April 2, 2017 Thanks Merv. Been away. Found blown fuse on negative battery terminal. Problem solved. Thanks again. Mick 2 Quote Link to comment Share on other sites More sharing options...
