Water issue
HAVAGO
Just wondering has anyone had an occasion when they found water getting into the front boot.
i opened the boot a day after the biggest downpour ever only to find water in the boot, yet I cannot see where it got in.
As well as the latches, it could be the seal on the boot doors, and there is a small drain hole in the bottom edge of each door. I replaced the seals with a better product than the original (Bunnings has a huge range), put a small piece of fine plastic pipe into the holes (don't push in far), and at Kedron's suggestion,  filled the gaps around the latches with a heavy grease. I used wheel bearing grease as it has a high melting point. It ain't pretty but it works!
Bas
