Rod
Battery charger / inverter
Is the Enerdrive combo
60 battery charger
1600 inverter
a good product for the ATV
Rod
Hi Rod
We have the Enerdrive 3 bank 60amp charger combination with a Xantrex 1800 inverter and have just fitted  2x 120amp lithium  batteries and the system is working a treat.
Is lithium batteries the way to go
Hi Rod.
Is lithium batteries the way to go.................Absolutely.  That's why most manufacturers of hi-end caravans are fitting them as standard.
However, upgrading from AGM batteries to Lithium batteries can be expensive,  so shop around and choose a supplier and a system that suits you.
Cheers from Pete.
Hi Pete
Itech world in Perth currently have 120amp lithium batteries that can be connected in series for $899 free delivery or can be cheaper to pick up.
Working very well without changing the original system and only 13kgs each.
That is very cheep for 120 lithium
how long have you had them
and you say my standard charging system
will charge them ok
do they need to be charged at 14.6v
Hi Rod
They are a direct drop in replacement for the argms, same physical dimensions.   Max charge is 14.7v and all reports I read none were detrimental.  I have only had ours a week and so far so good,  only time will tell.  Weight of each battery is only 13ks so a total of 26kgs against the 100kgs for the old agms, which I might add lasted nearly 7 years.  Set them up on your  enerdrive  charger by the instructions that came with it.  I now have an extra box up front.  I got $50 back from the recycling depot for the old agms.
Thanks Merv
very keen to see how the lithium perform
how much solar do you have on the roof
is 2 batteries enough for all your needs
when I replace mine I think I will do all 3
390 solar & the 2x 120 lithium is the equivalent of the old 360agms or so I am told.
The Itech 120amp lithium batteries now have a 3 year warranty.
Thanks Merv
for the great info
With you’re xantrex 1800 inverter did Kedron fit it and wire it in when the van was getting built
OR was it fitted later
when I fit my inverter
i am wondering how to get the wires back inside to a change over switch
Rod
Hi Rod
Factory fit.  The only piece of electrical that we have had to change was the battery charger.
Cheers Merv
Ok thanks merv
may be some one else can help me with permanent inverter institution
My problem is the pins on the inlet socket will be live when the inverter is on
How do I fix this problem
Rod
Hi Merv
when you installed your lithium batteries
from itech did you have to reprogram your solar controller
I have a tristar TS60 MPPT
i assume you have the same
Rod
Hi Rod
setting 3, and make sure you disable equalisation at number 7.
i have been advised by enerdrive to have a custom profile loaded when I get to Darwin just to make the system correct for the lithium.
We had a custom program installed into the old solar controller by Wheelhouse Marine in Darwin  and all seems to be working quite well.
They were recommended by Enerdrive to do the job, apparently the latter solar controller  already has the lithium algorithm in it.
