BJW44 Posted September 26, 2015 Report Share Posted September 26, 2015 Any one that is towing with a 200 series Landcruiser advise the location of your brake controller and two way UHF radio in the Dashboard area, you advice would be appreciated. Regards Jim Quote Link to comment Share on other sites More sharing options...
tassie Posted September 26, 2015 Report Share Posted September 26, 2015 Jim,I removed the ash tray an had the P3 fitted there.cheersGreg Quote Link to comment Share on other sites More sharing options...
BJW44 Posted September 26, 2015 Author Report Share Posted September 26, 2015 Thanks Greg, I was thinking of installing the "Redarc Go-Pro" .Regards Jim. Quote Link to comment Share on other sites More sharing options...
Mrs Lynn Astill Posted September 29, 2015 Report Share Posted September 29, 2015 Hi Jim.I have a Tekonsha, but the reason I am commenting is that I origially had it where the ashtray is, but had it moved to the usual left side of the steering wheel near the left knee. The reason being ease of access in emergency van breaking. Have had to use it on the Kalumburu Road and I am thankful that I moved it...RegardsChris Quote Link to comment Share on other sites More sharing options...
John and Tina Posted September 29, 2015 Report Share Posted September 29, 2015 Hi Jim might be worth looking at the ARB red arch system. fits under the dash with just the switch on the outside which allows you to dial up the brake intensely as well as emergency stop by pushing the button. fits nicely in the right hand corner and no interference with air bags. I had mine installed 12 months and have no experienced any problems. Warm Regards John Quote Link to comment Share on other sites More sharing options...
BJW44 Posted September 29, 2015 Author Report Share Posted September 29, 2015 Thanks Chris & John for your response.John the "Redarc Go- Pro" is the one I have been looking at.Regards Jim. Quote Link to comment Share on other sites More sharing options...
Stu and Jean Posted October 12, 2015 Report Share Posted October 12, 2015 Hi Jim, We had a P3 in our 100 series. Now we have a nice new 200 series and it came with a tow pack fitted with the new Redarc Tow Pro. It works really well,is proportional and a lot easier to operate than the P3. Im really happy with it. Its not the same unit as the older solid state type that arent proportional. If you have stability control fitted to the van such as DSC you will need a load resistor fitted but thats about all. We had a remote type VHF fitted that has all the controls on the microphone. Its mounted behind in the middle of the dash out of sight. I had a good auto electrician fit it. Hope that helps Cheers Stu Quote Link to comment Share on other sites More sharing options...
BJW44 Posted October 12, 2015 Author Report Share Posted October 12, 2015 Hi Stu.Thanks for your response.The tow pro is the way I will go for the brake controller, I haven't decided on the UHF radio yet but the type you have described sound like it may be worth looking into.Regards Jim. Quote Link to comment Share on other sites More sharing options...
Merv and Di Posted October 12, 2015 Report Share Posted October 12, 2015 Hi Jim A good Aussie radio is the GME 3540 or the new 3550, both with mic controls. The prices vary so do a search. Cheers Merv Quote Link to comment Share on other sites More sharing options...
BJW44 Posted October 13, 2015 Author Report Share Posted October 13, 2015 Hi Merv.Thanks for your advice I will have a look at the GME website.Regards Jim Quote Link to comment Share on other sites More sharing options...
BJW44 Posted October 18, 2015 Author Report Share Posted October 18, 2015 Hi Merv and Stu.What type of UHF radio antenna have you installed with the radio? I have not got a bull bar or nudge bar and probably will not be fitting one.Regards Jim. Quote Link to comment Share on other sites More sharing options...
Merv and Di Posted October 18, 2015 Report Share Posted October 18, 2015 Hi JimI got my GME TX3540 from GadgetCity online, they were the cheapest, but some offer deals which include aerials so have a good look at them. Mine was $398.00 del. I use a 6+dbi 900mm aerial which gives me good overall reception which I have fitted it into a factory mount position on the Chev. But I have also fitted a 3g aerial using a "bonnet mount" because I too don't have or want a bull bar. There are specific models of the mount available for various vehicles so just ask Mr Google.. "CB bonnet mount 200 series LandCruiser". Sorry photo got rotated.CheersMerv Quote Link to comment Share on other sites More sharing options...
BJW44 Posted October 19, 2015 Author Report Share Posted October 19, 2015 Thanks Merv I will follow up on the mounting brackets.Regards Jim Quote Link to comment Share on other sites More sharing options...
TonyH Posted October 19, 2015 Report Share Posted October 19, 2015 Hi Merv & JimMerv,With that aerial mounting bracket & the size (length) & weight of the aerial doesn't the mount flex & potentially crack & damage the paintwork?Jim,Have a look at this link https://www.autoelec.com.au/ssl/public_autoelec/store_v4/product_detail.asp?id=1351&cat=49 CU down the road.... Quote Link to comment Share on other sites More sharing options...
Merv and Di Posted October 19, 2015 Report Share Posted October 19, 2015 Hi Tony It was one of my original concerns but I was pleasantly surprised to the fact it doesn't move at 100k's + with the 3G aerial on it. Cheers Merv Quote Link to comment Share on other sites More sharing options...
BJW44 Posted October 25, 2015 Author Report Share Posted October 25, 2015 Hi all.I have arranged to have the Redarc Tow-Pro brake controller installed next week along with the Tow-Pac at the dealership.I have also purchased a GME TX3550 S 5watt 80 channel LCD speaker microphone UHF Radio + Uniden AT870 6db Antenna. As the radio has a pure sound path mic/speaker and also a speaker on the radio body, this I have installed under the driver's seat which is out of the way.I purchased this unit as a package from Gadget City $419.00 which after a lot of research consider it to be a good price.As for the antenna placement I have to decided to go the bull bar install as I have got a good price for the install through the dealership.The next thing is the Redarc dual battery isolator Anderson plug and the constant 12vlt power plug to the rear of the vehicle for the Engel Fridge.Eventually I will upgrade the batteries to lager capacity prior to our trip next year but for now the new OME ones will do.I would like to thank everybody for their advice and input for my project.Kind Regards Jim. Quote Link to comment Share on other sites More sharing options...
