Zolle Posted September 30, 2015 Report Share Posted September 30, 2015 Query for those who have fitted after market extra solar panels.Where did you run the wiring of the extra panels - to the existing solar panel wiring and connect at roof level or run the wiring directly to the solar controller?If you ran the wiring to the solar controller where did you run the wires in the van assuming you did not remove cladding to run the wires along with the existing wires? CheersJohn Quote Link to comment Share on other sites More sharing options...
Neville and Kay Posted September 30, 2015 Report Share Posted September 30, 2015 JohnI fitted extra panel on roof & to connect I lifted one existing panel up & hooked up to it. I also hook to extra panels direct to the PL 60 Solar charger through an Anderson plug the bloke at Springers advised me how to hook it up.Hope this helps. Neville Quote Link to comment Share on other sites More sharing options...
ATV42 Posted September 30, 2015 Report Share Posted September 30, 2015 Hi JohnWe had an extra panel installed, Kedron did ours and hooked it up the same way Neville is suggesting. Just remember to upgrade the fuse for the panel you piggy back the new one to.CheersPete Quote Link to comment Share on other sites More sharing options...
