KenG1 Posted May 11, 2021 Report Share Posted May 11, 2021 Hi All, I have a split corner on Fiamma Vent 50 - Roof Vent Lid (pictures i can send) I was looking to just replace the lid part It is the type that pushes up on 2 arms from inside Any ideas on sourcing a part ? is that easy enough ? I was looking for a how to video ? Thanks for any advice Ken 1 Quote Link to comment Share on other sites More sharing options...
ATV42 Posted May 11, 2021 Report Share Posted May 11, 2021 Hi Ken I’ve just Googled the Fiamma Vent 50. There’s a fair bit of information there that might help you. I hope you find the right information there, or try a local caravan repair place. Looking at the above photo and as a quick fix, try and put a piece gaffa tape on the inside or the outside for that matter, and then cover the outside area with a weatherproof sealant, moulding it into the required curvature. It might be a quick fix until you can source a more permanent solution. Cheers from Pete. 1 Quote Link to comment Share on other sites More sharing options...
KenG Posted May 15, 2021 Report Share Posted May 15, 2021 Try CaravansPlus https://www.caravansplus.com.au/external/vents/parts/fiamma/ Quote Link to comment Share on other sites More sharing options...
