Alan and Liz Jones Posted August 2, 2009 Report Share Posted August 2, 2009 Hi everyone,I'm having problems with my battery charger ( Victron ce 12/40 Centaur ) in that when I have stored my van away in the shed and plug the 240v power in, the battery charger cooling fan keeps running 24/7. Can anyone tell me if this is normal, or should the unit shut down completly. Cheers Alan Quote Link to comment Share on other sites More sharing options...
RussnSue Posted August 3, 2009 Report Share Posted August 3, 2009 G'day Alan,ours also runs the fan constantly when turned on. I think it's normal, though unnecessary, as it appears to run when there is almost no load at all. I put a thermometer inside it and the temperature doesn't get to anywhere near hot, even under full load, so I guess it's doing its job.CheersRuss. Quote Link to comment Share on other sites More sharing options...
Alan and Liz Jones Posted August 5, 2009 Author Report Share Posted August 5, 2009 Hi Russ,Thanks for the reply. It appears that this is normal, so I have put a 10watt solar panel on the roof of the shed and wired it in through the PL40 regulator to keep a trickle charge going into the batteries. I will monitor this for a while and if it does not keep the batteries up I will put a time in line on the charger to come on say once a week for 1 hour.Cheers Alan Quote Link to comment Share on other sites More sharing options...
