McAndrew
Water pressure and flow issues
We are experiencing less water  flow and water pressure when hooked up to mains water in caravan parks. I have been advised that it could be a partially blocked Shurflo Mains Pressure Regulator Water Inlet? Has anyone else experienced this problem? and if so, what are the remedies? Any advice and help would be greatly appreciated. regards Macca
Hi Macca,
We experienced the same issue and were told the same thing as you.
So we replaced the inlet and had no change in result.
We just put up with it now
S & K
1 hour ago, Steve and Kez said:
Hi Macca,
Thank you
S & K
Thank you, I have ordered a replacement, will see hoe not goes
Macca
I would be interested to know if it improves or will you be like us and just ..................... "Go with the Flow" 😋
No improvement, I am also told that the problem could be in the hot water non return valve but it cannot be gotten to from outside and is right behind the diesel heater so may have to "go with the flow" as well
