Jaap
water fillers
Have the old style water filler you know the ones you put the hose into to fill the tank
Yesterday whilst filling the tank Disaster! the filler, before the hose to the tank, fell apart and water everywhere
Has anyone else had this problem our am I the lucky one ?
Have two fillers and the second one is also coming apart
Can the fitting be repaired using sikaflex?
Any other suggestions
Thank you
Hi Jaap.
That's a bit of bad luck. Sikaflex might be a fix to get you out of trouble, but I would replace them as a long term solution.
Pete.
Thank you
Sikaflex is the answer. The glue fixing the fixings from the factory is useless. We have needed to sika it in 2 caravans,including our Kedron.
Thanks to all who replied
Used the blue plumbers glue which seems to have worked
Time will tell I quess
Plumbers glue should be ok. I hope you also used the primer - makes a big difference!
Jaap
Just wondering are you Dutch ?
Robjewel
My parents were hence the name
