kakabarra Posted April 2, 2016 Report Posted April 2, 2016 Hi Guys, just curious if anyone uses a the trail a a mate jack as there jockey wheel and do they keep it mounted on a the frame whilst travelling? Also anyone used the trail a a mate cable kit? Cheers Quote
colnden Posted April 3, 2016 Report Posted April 3, 2016 Yes we use the trailer mate jack but not with the dolly wheel as you will never be able to push it around too much. We use the base plate and have the jack mounted high enough that it can't hit the ground. We then use a plastic block under the baseplate to take up the extra gap when disconnecting the van. Has been that way for 14 years. If you are worried about the jack creeping down when travelling then use a bungie cord to ensure it stays up. Den Quote
Merv and Di Posted April 3, 2016 Report Posted April 3, 2016 Hi Kakabarra X2, ours sits on the bar permanently up high and we use the cable kit to make sure it stays there. Cheers Merv Quote
kakabarra Posted April 3, 2016 Author Report Posted April 3, 2016 Thanks Den & Merv appreciate the advice, looks like I will go with this option, great to hear there are no clearance issues. Cheers 1 Quote
colnden Posted April 3, 2016 Report Posted April 3, 2016 Just ensure when you fit the jack and it is fully retracted that you have mounted it high enough on the A frame to give you the clearance required. Den Quote
TonyH Posted April 4, 2016 Report Posted April 4, 2016 As previously mentioned, if you are going to leave the trailer mate mounted on the drawer bar when traveling MAKE SURE the base plate will not 'hit' anything and rig up a securing cable/strap to stop the 'ram' creeping down. i speak with authority & real life experience on this as it cost me a new trailer mate, clamp and welding to fix up my blunder! Travel safe Quote
ATV42 Posted April 4, 2016 Report Posted April 4, 2016 Hi Kakabarra We use a trail-mate jack, but only with the base plate. We remove the jack from the A frame when not in use and store it in the boot. By storing the jack in the boot, it keeps it safe, away from prying eyes that might want it, and it also keeps it clean and dry. I have a piece of alloy pipe that fits into jack position on the A frame when the jack is removed and this prevents the fitting from rattling around. I concluded years ago that by removing the jack when not in use, it prevents someone from knocking it off, then what do you do !!!!!!!!! Cheers Peter Quote
kakabarra Posted April 4, 2016 Author Report Posted April 4, 2016 Thanks for all the feedback guys. Purchased and fitted the trail a mate jack today. At full height on the drawbar the base plate still sits around 100mm below the a frame. It appears this will be full height as the jack will not close beyond the existing welded mount. I guess one option is to take plate off and allow jack to be fully closed or as Peter indicated pack away when not in use. Is this about the average height other people have experienced, or is this not an issue? Cheers Quote
John and Tina Posted April 4, 2016 Report Posted April 4, 2016 Have you considered a 12 v Bulldog jack. Makes life easier. They were on sale at the Melbourne caravan show recently. Quote
Merv and Di Posted April 4, 2016 Report Posted April 4, 2016 100 mm is about right. Just secure it with the cable kit it makes it a lot harder for it to grow legs and walk. Cheers Merv Quote
Tolley Posted April 5, 2016 Report Posted April 5, 2016 We use the Trailermate exclusively and like ATV42 we remove after use and store in a locker. Simple really. Regards, Colin Quote
Michael Posted December 29, 2022 Report Posted December 29, 2022 Whilst traveling with our van with the trail a mate attached with base plate on the jack dropped down and hit a high spot on the road haven’t had any fluid leak but worried there may be some damage inside the sealed hydraulic unit?? 1 Quote
