Ormondo 2 Posted March 11, 2020 Report Share Posted March 11, 2020 Hi i seem to be getting water into my front storage locker / boot through the locks on my 2014 XC3. Has anyone had any experience on how to fix this problem ? thank you 1 Quote Link to post Share on other sites
Sandra 399 Posted March 13, 2020 Report Share Posted March 13, 2020 We too, have the same problem. Look forward to hearing from others to see if there is a way to solve this problem. We thought the water may be coming through the rubber seals. look forward to some replies. Quote Link to post Share on other sites
Wandering Slaters 95 Posted March 14, 2020 Report Share Posted March 14, 2020 If you mean the very front boots (where the batteries are kept) we are also experiencing this problem after all the rain. We presume that because they lean that the channels get full and overflow into this area. Just pulled out 3 very soggy towels. Anyone come up with a solution we are all ears??? 1 Quote Link to post Share on other sites
Ormondo 2 Posted March 14, 2020 Author Report Share Posted March 14, 2020 OK so I have found a supposed fix from another forum which I am probably going to try it includes nicking out the rubber seal in 2 places per door to line up with the door drain holes on the bottom edge attached are the photos the writer provided 1 Quote Link to post Share on other sites
Tolley 86 Posted May 16, 2020 Report Share Posted May 16, 2020 I solved that problem on my TE some time ago. The black rubber seal around all the latches was perishing and cracking. I enquired about purchasing replacement black seals. I found i had to purchase a whole new latch. So, I removed all the latches and then all the black seals. Cleaned all the black seals off all surfaces. Then simply used clear silicon and replaced the latches. Worked perfectly. No more leaks. I will be at the van later today and I will take a photo and post it here. It really is a simple fix. Quote Link to post Share on other sites
