the crow and i
the crow and i last won the day on January 1 2023
the crow and i had the most liked content!
11,402 profile views
the crow and i's Achievements
  • Conversation Starter Rare
  • First Post
  • Collaborator Rare
  • Week One Done
  • One Month Later
  1. Hi Nev Hi Nev Thanks for the reply, but I have an issue with the mudguard protrusion I would have to modify the guard as the cupboard is 520W x 550D x 795H Can you provide some pics? Regards Bryan
  2. We have an ATV with the door at front end of the van. I have seen washing machines fitted a cupboard on the right as you come into the van and would like to do the same, but the mudguard protrudes into the cupboard. Do Kedron have a mudguard modification to allow the fitting of the washing machine?
  3. Hi We have the same problem with the decals and I have tried to remove them with use of a hair drier with little success. How did you remove them? Cheers Bryan
  4. Hi If you are still looking for an 18 footer we have an 2006 18'6" Topender for sale contact me. Bryan ccoaldri@bigpond.net.au
  5. Hi Tony That’s the system, there is a motor on each wheel and it would be ideal for moving around my yard as the area I keep the van is tight. I have had a look at more pics. and don’t believe it will fit, I believe it will foul on the suspension. Cheers Bryan
  6. Hi Has anyone had and experience with remote purpleline Caravan Movers? Cheers Bryan
  7. Hi Laurie Any chance I could get a copy of the drawings? Bryan
  8. Hi Laurie I can't open the attached Replacement Leaf Springs for the 2006 Chevrolet Silverado 3500.webarchive Bryan
  9. Laurie I didn't buy them, I machined the retainers from solid blocks of steel. The retainers are bolted through the chassis with M10-1.5 class 8.8 bolts and have a 150 x 100 x 10mm backing plates. Each retainer also has an M10-1.5 class 8.8 bolt that passes through the block and the rear chain link. Cheers Bryan
  10. G'day Merv The endorsement shouldn't be a problem locating an engineer may be. Thanks Bryan
  11. Hi All I need to have a GVM upgrade on a Silverado 2500 HD any ideas on where I can have this happen? Bryan
  12. After a lot of procrastination I bit the bullet and machined up my own couplings and must say I am very happy with the result.
  13. Hi I do like your coupling and I will do the same. Where did you purchase the bits and pieces? Happy Days Bryan
  14. Hi Danny where did you buy the 2" lift kit? Bryan
  15. Hi Tony Change of plan not King Shocks now fox. I have spent hours on the net and this is the best deal I can find surprisingly it is a local company. The quote I received for Fox Shocks from Double Black Off Road Pty Ltd 17/150 Chesterville Rd,, Moorabbin VIC 3189 Ph: (03) 9553 0744, Email: sales@doubleblackoffroad.co 0-1"PERFORMANCE SERIES 2.0S MOOTHBODY RESERVOIR SHOCKS 980-24-959 Chevy Silverado 2500HD front 2 $425.00 $772.73 $850.00 0-1"PERFORMANCE SERIES 2.0 SMOOTHBODY RESERVOIR SHOCKS 980-24-955Chevy Silverado 2500HD Rear 2 $425.00 $772.73 $850.00 Freight: $0.00 $0.00 TOTAL $1,700.00 Cheers Bryan
